View Poll Results: Which battery would you choose?
Optima
37.45%
Odyssey 680
37.45%
Other Dry Cell/Lightweight Battery
25.09%
Voters: 275. You may not vote on this poll
Battery Replacement
Old 08-09-2010, 03:49 PM
  #51
josh7owens's Avatar
I just put on a deka ext-16l on my car. I like it but everytime I start my car I worry it wont crank over
also mine says 325CC but the guy that posted pics of his says 275?
Old 08-27-2010, 05:43 AM
  #52
AngryTurtle's Avatar
but its starts every time
Old 08-27-2010, 08:26 AM
  #53
josh7owens's Avatar
yea, it does. well see how it does once it starts to get colder.
Old 08-28-2010, 06:38 PM
  #54
INTJ's Avatar
Originally Posted by puredrive888,May 20 2010, 09:15 AM
You are not the only one. I had a friend that worked at Pepboys. Tons of warranty claims on them..
3x as much as their bosh batteries.
I have been using an exide orbital for my GTO. It's been great so far.
I had two die on me in a year, took the last one back to costco and they just laughed and gave me a standard one, saying that they will never tell another customer to buy one ever.
Old 10-13-2010, 11:01 AM
  #55
EagleDon's Avatar
Originally Posted by innovation,Jun 16 2009, 01:12 AM
u can search s2ki for odyssey pc680 and a lot of people run it.
i just bought mine recently after my battery couldnt hold a charge after 6 years.
I am pretty much leaning towards the PC680 based on its CCA and size. My plan is to replace the original battery with the Drycell PC680 and locating it behind the passenger seat. The size is thin enough that makes the passenger seat set forward only 3" from the back wall.
I will post more info once I do this relocated mod.
Old 10-14-2010, 02:49 PM
  #56
Boofster's Avatar
Just to clear up the DEKA models:
The EXT16L has the polarities flipped.
We need the EXT16 (no 'L') for the S2k.
Correct me if I'm wrong but the previous posts confuse this and even the pictures posted show a EXT16.
Old 10-21-2010, 08:53 PM
  #57
EngineerX's Avatar
Both will work. I actually used both the ETX16 and ETX16L and found the "L" version to work best for my setup. I needed another battery for my Subaru so used the ETX16 for that.
The "L" posts end up in a better spot for my setup - I did get rid of the batt tray and made some brackets.
However if you use the OEM location then the ETX16 is better. But it's nice to get rid of a full 10 lbs when you get rid of the tray.
Old 10-27-2010, 01:21 PM
  #58
Ilike2DRIFT's Avatar
Just ordered a ETX16!
we'll see how it works in chicago weather...
Old 10-27-2010, 01:58 PM
  #59
josh7owens's Avatar
you wont have any problems. Congrats!
Old 03-19-2011, 03:56 PM
  #60
dhean's Avatar
For those with the Deka ETX16, does it work with the OEM mounting brackets without modifications?
Quick Reply: Battery Replacement
