Aut cooling pate effectiveness
Old 03-24-2008, 04:29 PM
thorax's Avatar
Default Aut cooling pate effectiveness
I just ran my car with and without the cooling plate. i found the temperature seam to be hotter with the cooling plate. I was wondering if anyone else has proof whether the cooling pate is effective with stock airbox? and yes i did reove the oem cooling pate thx
Old 03-24-2008, 05:31 PM
Habitforming's Avatar
which temperature, IAT or coolant? How did you measure, to say "seems to be hotter"?
I would expect that the plate has a greater effect on allowing the engine to breathe freely (with possible mild ram air effect at speed) than it does on IAT.
Old 03-24-2008, 06:09 PM
thorax's Avatar
IAT seam to be be hotter than with the stock plate
Old 03-25-2008, 07:23 AM
Administrator
Ludedude's Avatar
What? Some whiz-bang look-at-me-now mod that doesn't do what it says it does? How's that even possible?
Old 03-25-2008, 08:06 AM
Saki GT's Avatar
You removed the OEM plate that keeps pressure up and air going through the radiator, so of course temps will be up.
Old 03-25-2008, 08:49 AM
street_ruler's Avatar
yah i kept the stock stuff there and put this plate over the top...mine has that ram air duct on it.
i noticed that after a jaunt on the road the air box is actually cold to the touch where as before it was quite hot. but as for coolant temps, because i left the stock stuff there, i had no change.
Old 03-25-2008, 09:05 AM
Olegator's Avatar
take an obd2 scanner, and do it over looking at the IAT temperature
Let us know how it works out. BTW I won't be surprised if it actually will be hotter with the "cooling" plate
Old 03-25-2008, 09:14 AM
AP2S2.2K's Avatar
[QUOTE]What? Some whiz-bang look-at-me-now mod that doesn't do what it says it does? How's that even possible?
Old 03-25-2008, 11:47 AM
GT_NFR's Avatar
What did you measure the IAT with? any numbers?
Old 03-25-2008, 08:11 PM
thorax's Avatar
i used a bod2 scanner
Quick Reply: Aut cooling pate effectiveness
