Ap2 Center Console HELP
So my center console cup holder door won't retract by itself, could someone do me a huge favor of taking their console out and taking a picture of the door retracting mechanism on the underside? There are no pictures of it online. Thanks!
You sure it's not filled with gummy, fossilized Coke? I think you're going to have to pull the console to fix it anyway.
-- Chuck
-- Chuck
It's a coil spring sort of mechanism, latches on to the door and sort of rolls up when open. Taking it apart is easy enough, pop off the console and take off 8-12 screws(?) and then disassemble. Cleaned mine with isopropyl alcohol and q-tips.
Received 1,716 Likes
The spring is a piece of ribbon spring steel that moves with the door.
How do you insert/align the spring properly...and then how do you insert the separator without breaking off the plastic tabs (ears?)...I guess that's where I'm stupid and confused...I need a visual
