Amuse GT1 kit exhaust system
Hey guys,
I just purchased a S2000 shell with amuse gt1 bodykit fitted to it. It comes with a custom twin exhaust system which I have been told by the owner that its too loud and was made poorly.
I just need to know will custom 76mm single system will be good or shall I go for a twin? I will be supercharging my S with Vortech v2 kit at the end of August as well.
Thanks
Thanks
Supercharger will add noise to an exhaust so 76mm or 3" inch exhaust will be loud.
If your going with high psi (12+) then might be worth it, otherwise I would stick to a 2.5" or 63mm exhaust. If you're going dual try to keep the split equal length.
If you're going to track the car, make sure you know the noise restrictions in your area as that could suck if you weren't allow to hit the track with your custom exhaust.
BTW Singles typically produce more power but at the expense of sound levels.
It's up to you, if you're stick of loud exhaust I would do the dual 63mm exhaust muffler with a resonator.
internet tough guy
09-16-2008 07:28 AM
