Aftermarket seats in a 06 with airbag still workin
Well since my seats got stolen recently, im looking into aftermarket seats. everywhere i read says that the airbag light will be on because of the passenger side seat. Is there a way to turn the light off, have aftermarket seats, and still have the airbags working? Also, i know the passenger side rail is different, does anybody know where i could order a rail for a bottom mount bride seat? (driver side is the same as the 05, so i should be ok for a rail there) thanks in advance!
Driver's side, just unbolt the seat position sensor and plug it in. I bought an extra one. This sensor only works when the seat is VERY close to the steering wheel, basically all the way forward. Once you have the seat a few clicks back, it does not do nothing ... its sort of a hall effect sensor, I guess. Just plug it in and you will be fine.
Passenger's side. You need to remove the two weiight sensors and the SRS box from the stock seat and place on the new seat. Once this is done you HAVE to take the car back to Honda in order for them to get the sensors recalibrated. The process is a pain in the ass and they can only do it.
https://www.s2ki.com/forums/index.ph...c=562153&st=25
corrado_driver
06-18-2011 03:31 PM
