Aftermarket or OEM Headlights?
So the two inner headlight tabs on my passenger side headlight are broken completely. I've been looking at replacing the one headlight with an OEM unit or replacing both with a stock look alike set. My two aftermarket options are listed in the links below. I've never bought aftermarket lights before nor do I have faith in them but I do know a handful of friends who have bought them for other cars and have had no problems. My biggest dilema is do I pay $400 for 1 OEM light shipped or pay $450(after military discount) for an aftermarket set of 2. Any input?
(And before someone flames this post I would never hook up Halos to my car , the 2nd aftermarket headlight has a single Halo but I would not wire it up)
http://www.andysautosport.com/honda/...r00000791.html
http://www.tunersdepot.com/Lighting/...AP2-96302.html
I'd probably buy a matching set of aftermarket. Make sure there is some decent warranty. The housing itself is pretty basic stuff and unless a seal goes there isn't much to 'get wrong'.
If you buy one OEM, it will be a lot newer looking.
If you go aftermarket...be sure to swap in your OEM projectors if you want a proper cutoff. I was contimplating going with the replica AP2 headlights and swapping them over but found some JDMs instead!
I'm just going to get the OEM light and go from there. I just can't trust an aftermarket pair. I'd rather do it right the first time.
Definitely stick to OEM. I had aftermarket halo's and they got a lot of condensation in them. Plus like someone else said S2000 projectors are unmatched and it would save you time and keep the factory seal on the headlights.
Gig the 2 inside tabs are broken so the light can't be tightend down. My passenger headlight is literally on my car because the fender and bumper keeps it there. The bolt underneath are fine but with the 2 busted tabs I dont know how else to secure it.
