Aftermarket Gears
Old 01-04-2009, 05:43 PM
Jacksparrow's Avatar
Default Aftermarket Gears
I bought an used s2000 from a honda dealer in august it came with some mods(coilover,intake) and I think it might have some gears is there anyway I can tell without pulling anything apart?
Old 01-04-2009, 06:05 PM
krnmike's Avatar
compare / calculate the rpm and mph @ each gear
there should be a post on it.
Old 01-04-2009, 06:16 PM
nightcrawler7188's Avatar
post your max speed in each gear
Old 01-04-2009, 06:29 PM
negcamber's Avatar
If you have an ap1 with stock wheels you should be turning 4500rpm in 5th gear at 65mph.
Old 01-04-2009, 06:38 PM
yeah i still like the idea of making him max out each gear and posting the speeds
Old 01-04-2009, 07:46 PM
s2k aok's Avatar
yeah have him bang on the rev limiter for a few seconds to make sure he's really tapping out the revs...
but, if you really want to know what gearing you have use this page for your calculations...
http://www.turnzero.com/technical_resource...gear_calculator
Old 01-04-2009, 11:56 PM
SOHCmyDOHC's Avatar
does the rear make a slight whining sound? most aftermarket gears out there make a distinct whine. some ever so slightly
Old 01-05-2009, 08:01 AM
I tried what negcamber told me to do I have stock wheels and at 65mph im at around 4.1k-4.2k rpm and yes the back does make somewhat of a whining sound ^
Old 01-05-2009, 10:24 AM
ahrmike's Avatar
^the top speed W. gears will ONLY work if you have a speedo calibration. if you dont the speedo will just give you the wrong speed
idk if you can do it on the S since it has IRS, but if you spin the diff and count the rotation of the tires you'll have a good idea. (it worked on my solid axle camaro).
Old 01-06-2009, 02:36 AM
SOHCmyDOHC's Avatar
look at the tranny and see if there is any wires spliced into the speed sensor. If so you most likely have aftermarket gears with a speed calibrator. Look at the diff itself to see if it looks like it has been opened before. Same with the driveshaft/propeller shaft. Look for tampered bolts.
****If you don't have a speed calibrator installed****
If you have a friend who has a stock vehicle and match speeds on freeway. Do you have a GPS? If so use that and try to check actual speed versus your dash read out.
You can try the one tire rotation compared to driveshaft rotations also like mentioned above. This only give you an estimate. Gears come in 4.10, 4.30, 4.40, 4.44, 4.56, 4.57, 4.77 ratios
Other than that you have to take the diff out and count teeth.
Quick Reply: Aftermarket Gears
