4 point harness
4 point harness
I'm trying to figure out if I'll be able to keep my stock seats and be able to install a 4 point harness. I have an 05 S2K silver exterior with red and black interior. This is my favorite years and colors so i don't want to change a ton of the stock parts. If anyone has any info or tips please let me know. Thank you
From my research you can use a 4pt cusco hoop bar with the harness bar. The only way you would be able to full recline will be if you remove the harness bar. Although i don't know first hand, this the result i get. I plan on getting a 4pt cusco with the harness bar, but it will be removed for daily usage and just will use the harness bar from track/drag fun days.
Yes, for your sake don't use harnesses with stock seats as the belts can slip off in case of an accident. In general 4 points are also not safe unless they're Schroth ASM.
