1.5 Way LSD VS Stock TorSen?
What does a 1.5 way (insert brand name here) feel like compared to our stock TorSen LSD's on street and on track?
Quaife is pretty good. Thanks for the info. How does that differential you installed differ from the stock one in terms of on road feel?
Why replace a torsen with a torsen?
Are 1.5 way and Torsen the same? The "way" type LSD's are clutch pack driven and Torsen is helical so the behaviour of each is unique. There must be a reason why some guys have opted to go the "way" route instead of sticking with the Torsen we have as standard. I hoped this thread would get them to share their experiences/reasons why
Quaife and our stock LSD use both the same gear type construction.
Torsen is actually a brand but it's also contraction for torque-sensing so I guess it's correct to call a Quaife Torsen as well
1.5 way usually refers to the clutch type LSD which works differently.
https://en.wikipedia.org/wiki/Limited-slip_differential
I'm no expert. But one thing I do know is a torsen needs tor to be able to sen. If a rear wheel lifts mid corner, like a dog marking its territory, there is no longer any engine torque being applied to that wheel for the torsen to sense.
An unfortunate side effect of how the marvel of mechanical torque sensing diffs work is that in this scenario, all engine power is routed to the wheel in the air, and car stops accelerating.
I imagine track guys would hate this.
On the street its much more difficult to generate the types of forces required to lift a rear wheel from cornering. So its way less of a deal, or no deal at all.
I've gathered that the 1.5 clutch pack type offer very little in the way of trq feedback, which in our Torsen causes a lot of throttle on/off steer which isn't always desirable. The 1.5 can be set up to run the car very neutral, allowing you to be more aggressive on throttle out of a turn without the car wanting to oversteer and bite you in the ass. The diff is just less influential in the dynamics of the cars handling behavior.
