08-09' CR cluster mod
So I have always loved the look of the CR cluster, looked to buy an entire cluster but apparently people want an arm and a leg for them. So after doing some research I found there are only 2 differences in a base 08-09' cluster and the CR version. The lens cover and LCD panel. These are the only 2 part numbers that vary. I opted just for the lens cover for the CR look on my base 09'. I'm not sure if the LCD panel for CR will give you the max power indicator or not. All I did was swap just the lens out. It is a plug n play for 08-09 only.
The part from majestic is $32
I plan do eventually use the power indicator but need to do some more research and see if the LCD panel is what I need, this piece is pricey but still cheaper than a used CR Cluster and you can keep your miles the same.
Before-
After-
Before-
After-
