06+ Possible Test Pipe CEL fix ?
I just found this part and think its a viable option to fix the CEL issues on the 06+
Weapon R about $45
http://weapon-r.com/english/index.php?main...roducts_id=6219
Cheapest I found was $30 shipped for this version, but will need to add the anti-foulers to make it longer:
http://www.strutking.com/fit-defoulerangled.html
what do you guys think?
Weapon R about $45
Interesting... so because its a curve it might make the mixture sensed more lean?
I was thinking of just putting a little bit of the cat material inside one of the regular anti foulers. That might make the A/F's lean enough...
We need someone who has an 06+ and has been unsuccessful in using the 2 staggered foulers. This will ultimatley prove that the 90 deg bend design works. There have been some MY06 cases where the CEL light isnt as trigger happy and need to filter those people out.
i have the Berk high flow metal cat on order. i also ordered a 90 degree O2 extender. first i am going to try the metal cat with O2 sensor mounted in the standard place. if i get a CEL, i will then install the 90 degree extender and see what happens.
i will update upon receiving the metal cat from Berk. the cats been on order for 2 weeks.
