06+ AP2 Steering wheel into AP1
Anybody have experience with this? The newer steering wheels has a dual stage air bag which has 4 wires vs the single which has 2. Anyway to get this to work?
The SRS controller is different and there is a sensor under the front bumper so the systems are different. Looks like a lot of work to do this right. This thing is technically a small bomb pointed at your face. I personally would not mess with it.
Well...I figured out how to do it safely without re-wiring the system. It was quite simple actually..all I had to do was remove the dual stage ignitor system and switch it with the single stage. Problem Solved. NO splicing needed. Direct swap..
This is just what I did..so do at your own risk!
Step 1: Remove steering wheel and airbag - Xviper has a great DIY on that here..
http://forums.s2kca.com/showthread.php?t=13254
Step 2: Remove airbag ignitor
Remove the 4 Bolts on both air bags
Step 3: Swap them over and place the bolts back in..DONE!
