06+ aftermarket steering wheel...
#21
Originally Posted by urBan_dK,Nov 1 2010, 03:24 PM
Should be easy to figure out. Find resistance of airbag with a multimeter, find resistors of appropriate value, plug them into the right spot.
I have an 06 (as many others here) and don't have any VSA issues. Key thing to remember is that our hub has 3 prongs/keys on the hub itself. The third notch is for the steering wheel sensor. IF that is not there, the VSA light will trip.
#22
Originally Posted by 99SH,Nov 2 2010, 09:07 PM
Just wanted to point out to NEVER EVER do this. Connecting a typical DMM to your airbag may trigger it if you're not using an ordnance meter.
So what aftermarket hub are you using that has these prongs there?
#23
I have an HKB hub, but they're very hard to find nowadays. But whichever hub you buy, you can easily cut in another notch with a dremel. Make sure the notch is deep enough like the other two. Just compare it to your stock steering wheel when you pull it out, and duplicate.
Example below of your typical honda hub with TWO notches. This would work, but would trip the VSA light.
#24
I know my Momo hub has the 3 notches
Pulling the fuses doesn't reset the SRS, Fish. The way the circuit works, the SRS module constantly monitors for the proper resistances in the airbags/seatbelts. If at any time it registers that one of those resistances is not present/incorrect, it triggers a hard code that can only be reset through the actual reset procedure (either with the tool or with a jumper as described in the Helms). This appears to be why some people have the issue and others don't (or as in this thread - the first time the battery was pulled, so the code wasn't set by the SRS module. The second time the wheel was pulled, the SRS module registered the change in resistance.). I don't know that the battery has to be disconnected for the code to not be set, but it's a good practice to disconnect the battery when dealing with any of the SRS components.
Short and sweet: Pulling the fuse/battery doesn't reset the error code as it's not stored in eeprom (like a CEL is).
#26
Just call or PM evasivemotorsports, their blue Voltex S2000 is an MY06 running an aftermarket steering wheel.
I am sure they will be very helpful and have what you need too.
#27
Also, from what I've seen... even with the SRS lights on due to the new wheel, you can still clear them AFTER installing resistors, without reseting the system. A friend of mine had the SRS light on due to a loose resistor. Installed it correctly, and the SRS light actually cleared itself.
#28
#29
Originally Posted by FISH22,Nov 2 2010, 06:10 PM
I'm also wondering, if pulling the wheel off while the battery is still powering the car, can trigger the lights? Cause you said you pulled it off again to realign it. Did you pull power from the car before that?
I know there are some sensors around the car, that when they're disconnected(with flowing power), they'll throw a light or CEL.
You should never be messing with any of that stuff without disconnecting the battery first, anyway.
#30
