04-05 and 06-UP AP2 have cluster difference?
I have a 2007 AP2 S2000. Are there cluster difference between 04-05 AP2 and 06-UP??? Could I purchase 04-05 AP2 cluster? will this work on the 07 s2000? If anyone can help me out, that will be great. I tried searching if there were any difference, but no luck. Maybe S2000 communities can shine some light on this topic. Thank You in Advance.
the layout of the coolant and gas gauges is a bit different, and possibly the ap2 06+ cluster has a VSA off light. thats pretty much it. Im not sure if you will have any major issues with running an 04-05 cluster
I really can't tell the difference on the temp and gas. Anyone has a comparison pictures? That will be helpful.
There's no difference in the tach/temp/gas layout between 04/05 and 06/07, those changes didn't come till 08. The differences will be the ambient temp gauge on the 06/07, lights for VSA, Oil Minder, and probably some other stuff I'm not thinking about. Also, the 06+ cluster uses the highbeam indicator to show the DRLs are on, but it's very dim and hard to see during the day.
I wouldn't install an 04/05 cluster in your car, you're just going to lose too much stuff.
08-09 CR
08-09 BASE S2000 Same cluster just minus the Yellow accents in cluster but same layout
08-09 CR
