S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Roll hoop cover - splitting?
Old 06-17-2020 | 08:51 AM
  #21
rrounds's Avatar
Originally Posted by silenc3x
A body shop that did work to my car split them before realizing that wasn't how they were removed.... I could never get them to stay together after that.
Had to buy new ones. Now I have AP2V2 hoops with faux speaker inserts installed. Looks infinitely better with the top down, but it wasn't cheap.
Could you post a pic or two of your faux speaker inserts? I take it you just left off all the plastic and now you have the bare metal hoops.
Rod
Old 07-02-2020 | 05:55 PM
  #22
summitrider2012's Avatar
I’ll sell mine ready to go out of my 07
Old 07-02-2020 | 06:05 PM
  #23
https://www.s2ki.com/forums/nes2ko-m...hoops-1188957/
Old 07-03-2020 | 04:05 AM
  #24
hd17f's Avatar
Thank you but I found a set for 250 like brand new
Old 08-13-2020 | 02:38 PM
  #25
Nedpoins's Avatar
Default Roll Hoop Cover Solution
I had the split roller hoop cover on the passenger side and used a product called Goop that someone on the forums recommended. It worked! It has a little elasticity to it when it cures that allows the hoop to expand a little in the sun without cracking the seals happened on other epoxies that I tried before. It's 9 bucks at Amazon.
Old 08-16-2020 | 08:35 AM
  #26
shrykhar's Avatar
Interesting, there's a 'GOOP II" that's supposedly stronger and an automotive GOOP for car based applications ... wonder if those might work too.
Old 08-19-2020 | 05:31 AM
  #27
randomwalk101's Avatar
Just use some JBWeld...and use duct tape to hold it while the JB weld dry...once dried, it'll be on there forever...
Old 08-02-2021 | 12:01 AM
  #28
scallaghan99's Avatar
Its a shame that Honda don't do a production run of spare trim and these hoops
Old 11-26-2021 | 12:56 AM
  #29
Orelion's Avatar
Please don't drill or glue your splitted roll hoops!!
You need to fix this and weld it as they did at the factory. Please follow my tutorial on Youtube and you will fix this problem for good.
Really easy to do, or show it to your mechanic so he can do it for you.
Mines are done for almost a year now, and they're still solid welded together OEM look (no holes, drills, messes with glue).
Happy to help you solve this usual problem on s2k
jimnfrs (04-07-2022)
winter5470
07-04-2019 08:10 AM
Roadkill
04-05-2008 03:19 AM
CoutureB
02-28-2006 09:27 AM
Vash
05-25-2004 10:50 AM
Quick Reply: Roll hoop cover - splitting?
