renew seats S2k 2006
If you can do it yourself, I'd recommend these:
https://leatherseats.com/shop/specia...000-black-pkg/
I got them and they look, feel, smell OE.
The following 3 users liked this post by bruthaboost:
Expat2 (06-08-2022)
(From the website.)
Black with grey center panels, although not OEM, would brighten my Boring Black(tm) interior. Like the roof professional installation may be the best option to get it right.
-- Chuck
This is NOT a cheap slip-on cover.
-- Chuck
Here are a few pics. Apologies for the Dutch angles, the windshield is in the way. I kept the images large so you could try to get an idea of the fitment/finish. If you do these yourself, you can add seat heaters while you're there. You can see the on/off toggle switches next to the power socket. Hope these help.
Expat2 (06-10-2022)
All you need are:
Heat gun/water spray bottle to smooth/tighten the leather after you've fitted it.
Basic hand tools to remove and disassemble the seats.
Hog rings and hog ring pliers to apply the new skins.
The difficulty you may run into is the condition of the seat foam, especially the outer bucket portion of the lower seat. This foam tends to get smashed and there really isn't a great way to repair it. I just bought OE replacements. I haven't checked on the availability of these recently so your luck will vary. Feel free to message me if you have any other questions.
Expat2 (06-10-2022)
Thanks again, but a solid 4 is probably too much for me...
First talk to the upholstery, if they are able to redo the side parts. They worn, but in Germany i faced the same problem on 2002 s2k
and the shop there could fix it without replace it.
