Remove Radio Door Face from trim panel
Sponsor
Since I had the stock radio door signed by Shigeru Uehara, I bought a CR radio door. I thought it would come with the entire trim panel as well, as that's what it looked like it included. Turns out it's just the door face.
I've been fiddling with the spring mechanism to try to replace the door, but I can't seem to figure out how to take it apart. Anyone know how it's done?
Thanks!
Thanks!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
I havent personally done it myself, but this thread seems to show what to do.
https://www.s2ki.com/s2000/topic/251...im-panel-pics/
Hope that helps!
Hope that helps!
Keep a very close eye on the spring as it can get loose on you on removal. To reinstall it you need to pre-load it upon installation so it has pressure to open the door on release, hard to explain without seeing it in front of me. Take very close note of the door before your pull it appart. Push out the pins and reinstall in reverse, the spring is very small so be careful not to lose it.
I've been looking for an autographed radio door, if you ever want to sell it hit me up, I'd love to purchase one.
Good luck with the swap.
Sponsor
Thanks guys!
__________________
_________
_________
