rear defroster sub wire harness window support
I am putting on a new after market top. I have not been able to remove the old defroster sub-wire harness from the old top because I can't get the plastic box wire support that holds the wire harness in place between the two window connections. I ordered a new harness and then found that I need to get that little plastic support box because the harness does not come with it. I ordered what I thought was the box but turns out that it is just the cover for the bottom part that is apparently only on the window which is available by buying the whole soft top. This is Honda genius at it's best.
Have any of you guys had to deal with this? And what do you use in place of the stock support box. I would supply a picture if I could figure out how to upload it.
Suzuka_Joe
07-20-2011 03:28 AM
