Which PCI Seat Rails?
'05 AP2 and I want to install a Recaro Pole Position seat as low as possible on the driver's side.
I've read that PCI seats rails are working out well for guys, but not sure which version/part number I need.
Seems like they have revised entire mount to get it lower and wider for a Recaro at some point?
Anyone have some insight?
NeoChaser (02-11-2020)
I purchased a Recaro pole position and a PCI "adjustable" seat mount from JHPusa on black friday.
I purchased the non-slider version. Meaning, if I want to adjust the seat forward/backwards, I need to un-bolt the 4 bolts holding the rail together to adjust. While slightly annoying, no one drives my S but me, so skipping the slider means getting to sit a bit lower. I believe the slider version is about $65 more.
Feezy (09-23-2021)
Which is the correct Slider Seat Mount version to use with a Recaro Pole Position (ABE)? Narrow or Wide?
Can you get very low (onto the carpet) with a Recaro Pole Position or ist it too wide and the seat will clash with the Sliders?
Sent a PM to Rogue Motorsports a few days ago as I was planning to order the specific brackets mentioned in this thread through them but got no response back.
I ordered the Nagisa super low rails to use with a Pole Position seat assuming either ever actually ship (both seem to be backordered from another galaxy). From searching here they are the lowest rails I could find and I need all the head room I can get - just over 6'4" with a long torso here. If I sit on the bare floor the top of my head is almost dead even with the top of the factory roll hoop plastic.
mokinbird87 (09-16-2021)
Thanks.. Brian emailed me back and confirmed that S1 ‘wide’ slider is the correct one for Pole Positions. For passenger side I’m going with adjustable non-slider one — their website a little confusing but US AP2v1 (2004-2005) needs the mounts P/N SM-AP1-R-A1 (labeled 00-09 AP1/JDM AP2)
