S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Need help with Seat Upgrade
Old 01-01-2023 | 10:09 PM
robjoshua228@yahoo.com's Avatar
Default Need help with Seat Upgrade
I am sure there are some of you that know this inside out.
I took off my OEM seats to take them to be redone, I was going to do this anyways because they were in bad shape and when I sell the car (when I have to), it will be sold as completely stock. If I want to replace the OEM with the aftermarket set I have in storage (Sparco R100 in black), how do I rid myself of the airbag light, which came on as soon as I took out the OEM seats? Where do the OEM connectors go if the OEM seats are taken out? There are four connectors ounder the passenger side and one under the driver's seat.
Thank you.
Old 01-01-2023 | 11:25 PM
Another question, the passenger seat belt was bolted to the passenger seat, where is the seat belt attached if the seat is replaced? The driver seat is attached to the floor and I am not sure why it is simply not the same for the passenger side.
Cheers.
Old 01-06-2023 | 08:33 AM
Anyone, I wish the search function was a bit easier so I would not bother people . . .
Old 01-06-2023 | 08:46 AM
Chuck S's Avatar
Lots of folks use the search function -- that's how 18 year threads get replies. I don't use the forum search function. I use Google. search term:www.s2ki.com (What you're searching for) - (colon) - (www.s3ki.com) (or another site) (no spaces) Works for me here and elsewhere. Still turns up old stuff though.
-- Chuck
Old 01-06-2023 | 09:07 AM
Thanks Chuck, so disappointing that a solution has not been found after so much time regards.
Old 01-06-2023 | 09:14 AM
Vadster's Avatar
I think it may be because there could be liability involved. Someone posting how to defeat airbag sensors (if there even is one) is a "user assumes all responsibility" kinda thing for doing it.
Old 01-06-2023 | 09:29 AM
sam_spider's Avatar
Site Moderator
There is a solution, but those that did it are long gone from this forum which is why you aren't getting answers to a lot of your questions. As others have said, the search does work, but you have to put some effort into it.
From what I do recall swapping seats in an 06+ car, it's best to have a spare OEM seat bracket to hack up and reweld to the new seat, as you need the senors from the OEM seat. Most skipped out on this as it was/is difficult, so those that did swap seats in the newer cars rode with the lights on, or some other 'hack' to make it work. It is not something you're going to find a straight answer or DIY on, as Vadster above has already pointed out.
Old 01-09-2023 | 01:26 AM
Thank you. The problem here is that should one succeed in finding a knackered seat out there, how would one 1) guarantee it still has the sensor, and 2) how does one extract the sensor form the rail/seat and hook it up to avoid the warning lights when a new aftermarket sat is installed?
Old 01-17-2023 | 02:25 AM
veleno's Avatar
What year is your car? The 06+ cars are the only ones that need to worry about the sensors (from what I've read).
SD_ray
05-14-2013 08:36 AM
s2kvn
03-05-2009 07:23 PM
1.8TsBLOW
02-18-2008 12:13 PM
batikan
07-30-2006 09:04 PM
nsxinsac
04-02-2005 05:42 PM
Quick Reply: Need help with Seat Upgrade
