Footwell LED Lights
Footwell LED Lights
Hey guys,
I recently installed some footwell LED lights in my S. I wired them to the door latch so every time the doors are open the lights come on. The only problem is that ever since I wired these, my Compustar alarm trips ever so often (voltage/current from led related..?) I was wondering if there is another spot I could try wiring so that they still turn on when the doors open. How have you guys wired yours??
Thanks!
Thanks!
Although I used regular light socket that takes a 12 volt light bulb (these were readily available at car parts stores/Wal-Marts/etc)I ran a separate wire to the fuse panel, added a "add a mini-fuse" then tapped into each door ground button. When either door opens, the footwell lights come one ......
NsaneR3vs
13
11-14-2011 11:10 AM
