Disassemble panel button
Hi guys.
I need your help because I'm trying to disassemble a button in a panel and can not
I'm disassembling the button nr 4 image but I can not.
Can anyone tell me how to take it apart from the rest panel??
I have a new button and i want remove old button because it is very worn.
Regards.
Regards.
it's a bit difficult. first you need to remove all the screws holding the black and white pieces together. After than, you need to pull the knobs off, #2 and 3. Then the hard part is prying the front (black part) off of the white backing. If you look around there are clips on all sides. you need to basically use a bunch of small flat head screw drivers to simultaneously pry it off (while obviously not breaking them). They should separate after that.
