Some Engine Bay VTEC Bling
I thought I'd put together a quick writeup for one of the newer parts released from Skunk2 for the S2000.
This is the black series VTEC solenoid. It is an anodized billet aluminum body replacement.
The stock unit.
Tip: Loosen the 3 top bolts and pressure switch with the solenoid still attached to the head
side by side
swap over the spool gasket
top view
you can just turn the valve upside down to remove the piston/spring
swapped over
reinstall the top w/ supplied hardware
assembled
w/ the pressure swich blocked off (the block off is a seperate part)
mounted w/ the supplied bolts (note: 1 supplied bolt is longer than the others. It goes in the upper corner)
1 last clearance pic
The stock unit.
side by side
top view
swapped over
assembled
