Need suggestions with ASM rear fender flares
I need some suggestions, I got hit a couple weeks ago and would like to get fender flares instead of getting the fender repaired.
Just trying to figure out how to approach this. It seems that the over fender would fit over the damaged section. I would like to spend least as possible...
I'm wonder how i should pull out the dent:
1. use fender roller/ pull manually?
2. i would like to use 17x9 +30, do i need to cut the fender or just roll and pull it out?
I'm wonder how to cut, if thats the case. Thanks for any help.
it looks like your going to have to beat on the inside of the wheel well to hit it back into normal position. It can be done easily. You will also need to see if the over fender will cover up the damaged area and see what if anything needs some actual cosmetic work. My little bro just had is RX7 backed into by a guy in a huge ass bimmer and we worked it out with some hammers and a heat gun to pretty much near stock looking. Then we used the money we got from the bimmer owner (thanks mr bimmer) and used it to buy over fenders for all four corners! How does one even back into a car when the car he was driving has radar and backup camera?
DIY FTW!
DIY FTW!
GPW_LOVE_012
01-14-2017 10:29 AM
gs2000
10-02-2002 04:44 PM
