My DIY valve/spark plug cover
Old 10-30-2006 | 10:03 PM
jakub2000's Avatar
Exclamation My DIY valve/spark plug cover
Due to so much mechanical work in the last year my valve cover looked like crap so I desided to paint it. I got finally inspired by this ( ASM is my hero in the s2k world) and FF2Skip:
The plan was to order a AP2 spark plug cover since even in the year 2006 our market still gets the AP1 with a black spark plug cover. But than I desided to paint the one I have and keep the Honda logo on top. Here is the outcome:
My comments: I was too lazy to cover the holes perfectly, nothing that a bit of paint thinner could not remove later on. I did not sandpaper the original red paint to maintain a ruff finish, even tho' it came out a bit more shiny than I would like it to be. No wrinkle paint available here, otherwise I would use that. The letters on top have been sandpapered to a smooth finish.
Bad or good, tell me how you like it.
Old 10-30-2006 | 10:07 PM
JLuda's Avatar
I like it Looks good
Enthralled's Avatar
what did you use to paint it with.....?
Old 10-30-2006 | 10:08 PM
trustbran's Avatar
Clean job
Old 10-30-2006 | 10:09 PM
i</3speedbumps.'s Avatar
needs black wrinkle paint but good attempt
Old 10-30-2006 | 10:26 PM
jakub2000's Avatar
^yeah wrinkle paint would be better but we are very limited in paint choise here in Dubai (no idea why). I used Enamel black premium paint from made by ACE and Metalic gold also made by ACE.
Kept it in the oven for some time like Skip did LOL
Old 10-30-2006 | 10:33 PM
SOHCmyDOHC's Avatar
You can make your own wrinkle paint. First coat is gloss (make it tacky but not too wet) then spray flat black. Use a heat gun or hot hair dryer and it should wrinkle. Not as good as "wrinkle paint" since it takes a while to perfect it. Try it...
Old 10-30-2006 | 10:45 PM
hk_s2k's Avatar
looks pretty good
Old 10-31-2006 | 02:31 AM
Graphtuner's Avatar
looks good!
Old 10-31-2006 | 04:35 AM
05berlinas2k's Avatar
think it looks pretty good!!!
Ive done this once before with a B16 dohc civic valve cover and it started to peel with time...
how did you prepare the serface for the paint? and did you use high temp?
Quick Reply: My DIY valve/spark plug cover
