ZEX NMU PROBLEM
Old 06-01-2009, 09:47 PM
SixToeRen's Avatar
Originally Posted by directportjuicedS2k,Jun 1 2009, 09:35 PM
Both sensors have a Red/black wire, make sure your not on the sensor at the top of the throttle body.
I tryed that one also but here a picture of the connector I been testing
Old 06-01-2009, 09:56 PM
JuicedS2K's Avatar
It should be that top Red/Black one, push the button on the NMU, hold the pedal down for ten seconds until it starts flashing green, turn the NMU off, turn back on and should be solid green.
Old 06-01-2009, 10:00 PM
SixToeRen's Avatar
I'll give it a try tomorrow and let you know how it goes its getting late. Thanks for all your help.
Old 06-02-2009, 08:44 AM
SixToeRen's Avatar
It didnt work.
Old 06-02-2009, 08:49 AM
SixToeRen's Avatar
I'll paypal someone 100 bucks if they can get me correct wire within the next couple hours.
Old 06-02-2009, 01:03 PM
SixToeRen's Avatar
Originally Posted by SixToeRen,Jun 2 2009, 08:44 AM
It didnt work.
I guess I Must have doen something wrong ealier becuase its workign with the red/black hoooked up to the white TPS wire.
Thanks everyone.
Old 06-02-2009, 01:06 PM
Slows2k's Avatar
Good thing the car doesn't have a MAF...
Old 06-02-2009, 01:33 PM
JuicedS2K's Avatar
MAP, ha sorry it was late.
Old 06-02-2009, 02:15 PM
Slows2k's Avatar
Leave the throttle body alone. Go insulate all the wiring you just hacked up trying to check voltages. It looks like a rat has been chewing on them.
You will need to use either APP sensor A or sensor B input wires on the APP sensor.
The APP sensor can be found be following the throttle cable from the firewall, in is under a black cover on the left inner fender.
There will be a 6 pin connector. The 2 wire colors to check are red/yel and red/blue.
Each one of these wires are sensor inputs to the PCM. Either one should work. Do not short them together.
Old 06-02-2009, 02:43 PM
JuicedS2K's Avatar
Yea don't do what has been proven to work and do all this other work for no reason??? I would not ignore Zex or people who have a working nitrous setup. If its installed correctly, it will work.
Quick Reply: ZEX NMU PROBLEM
