ZEX NMU PROBLEM
ZEX NMU PROBLEM
When I installed my kit a week ago everything was fine, I pressed the gas all the way to the floor and I heard the soleniod in the NMU click one time like it shoud. Right before I went to fill the bottle up I tested just to make sure everything was fine but when I press the gas to the floor now all I hear is rapid clicking. When I test it sometimes it clicks once like it should and sometimes it clicks rapidly.
Im almost sure it has something to do with the TPS but everything is connected and hooked up correctly so IDK anymore .
Originally Posted by directportjuicedS2k,Jun 1 2009, 08:45 PM
also, if you have a window switch you have to program the NMU before you wire it to the window switch, and if you dont have a window switch, get one.
Anyone have the ECU pinouts for the 06+? I have the pinouts for the AP1 and it seems to be different. I should be able to tap it from the ECU.
I still have a window switch, bottle openener and purge kit i cant install yet unitl i find this bitch of a wire.
Originally Posted by SixToeRen,Jun 1 2009, 08:55 PM
This is starting to piss me off. I have a Zex kit with everythign hooked up besides the TPS wire. I tryed probing the three wires at the top of the throttle body and the six wires on the right side of the throttle body is non of them are giving me 0-5volts at 0-100 percent throttle.
Originally Posted by directportjuicedS2k,Jun 1 2009, 09:09 PM
My brothers SI is drive by wire and it was still the red/black wire. Every Honda i have installed on is the same red/black wire.
Originally Posted by directportjuicedS2k,Jun 1 2009, 09:21 PM
Make sure your on the TPS wire and not the MAF !
