which is your preference for oil feed?
There's a pressure drop as the oil moves upward to the head, then in addition to the pressure drop there is now a oil feed that is using an X amount of oil that is usually lubricating the valve train. Just wondering.
ive heard that the vtec pressure switch location can have flucuating oil pressure escpecially in rpms below vtec. dont know if thats true or not. which do you think would have the highest and most stable oil pressure; sandwich adapter or the factory oil pressure switch?
DO NOT use the VTec pressure switch to feed the turbo. When VTec is engaged there is not adequate pressure to feed to the turbo and to the head.
Where are you guys getting your info from, there is not one manufacturer of turbo kits I have ever seen that would back this? Have you measured the pressure at the port durning VTec engagment?
Do the research if you don't believe me, try looking up the oil Mase kits and see how they were run. Then look at the later models and I will let you guess why the change was made.
What location did Mase move the oil feed to the turbo to? I'm thinking about ditching my reocation kit since the Full Race manifold doesn't require using one and I was taking my feed from the relocation block on the block of the engine.
