WTF, car is all over the place WOT abobe 100MPH
Old 06-02-2011, 03:30 PM
Jack_in_the_Box's Avatar
sounds to be a bad case of excessive HP.the only remedy is even WIDER wheels and tires! 305!!!!!!!!!!!!!!
yall really think this thread is fer realz?
Old 06-02-2011, 05:10 PM
JoeyBalls's Avatar
Originally Posted by petawabit
how long have you had them on? when you get new tires, they need to break in a little due to a compound on the tires.
I have had them on for about 400 miles...........
Old 06-02-2011, 05:32 PM
s2000Junky's Avatar
Probably right
I tell you, when I widened my wheels 2" out back and added 295's, the car felt much more planted, what a nice feeling for an otherwise nervous handling car.
Old 06-02-2011, 05:34 PM
*JG*'s Avatar
my car actually did this back before i decided to build it up. Ended being that the wheel weights were wrong(not balance properly) and the car was out of alignment.
Old 06-02-2011, 05:45 PM
camuman's Avatar
def make sure they are balanced and installed correctly. if they are, then check your sway bar, check the axles, check the suspension. did you get an alignment after? make sure the alignment is in check.
sounds dangerous whatever is wrong!
Old 06-02-2011, 06:35 PM
JoeyBalls's Avatar
My wheel is cocked to the right a bit when I drive straight, I need an alignment too
Old 06-02-2011, 06:51 PM
20002point2l's Avatar
ive found that on high hp s2000's you need to be running stock suspension to keep the car stable at high speeds, i would get loose at the 1000ft mark at the track everytime no matter what tire setup i ran, including slicks. Once the stock suspension was put back on the car had zero issues.
Old 06-02-2011, 07:03 PM
euro2jdm's Avatar
Once you have achieved a proper alignment, check for wheel movement by trying to move the rims back and forth while they are free hanging. This could be an issue with bushings and joints. When they wear, they will cause wander and loose tracking. It could also be the alignment. If you find there is excessive movement in the wheels, see where it is coming from and replace that bushing/joint/arm etc.
Tires and after market suspension could be the cause but are less likely than an alignment or worn suspension component.
Old 06-02-2011, 08:14 PM
s2000Junky's Avatar
You have to quit hitting those curbs and potholes man
Old 06-02-2011, 08:29 PM
DFWs2k's Avatar
This and alignment
When one rear had about a degree more negative camber than the other, any kind of acceleration would almost make the car do a 360.
Quick Reply: WTF, car is all over the place WOT abobe 100MPH
