wrapping aftercooler?
Old 06-25-2013, 10:59 AM
  #21
james0933's Avatar
Hmm, really. I can see the fluid flowing when I take off the cap, but it's never gushing out. How do you guys have yours routed?
Old 06-25-2013, 11:12 AM
  #22
lude92_si's Avatar
With the stock pump I could see it move but now with the Bosch pump it will splash out the filler hole. Output of pump line goes to the port closest to the throttle body. The other port toward the front of the car goes to the top of my front mount heat exchanger and the bottom port of heat exchanger to the inlet of pump. That's how I just redid mine.
Old 06-25-2013, 12:22 PM
  #23
JawKnee's Avatar
Post vids of your fluid in action. I have the SOS base kit, but I have my water pump wired directly to the battery through a relay like the Vortech installation suggests. Car was not running in vid.
http://www.youtube.com/watch?v=dYWAM65UwNw
Old 06-25-2013, 12:48 PM
  #24
CoolGuy094's Avatar
Originally Posted by lude92_si
Maybe I just want it to be really cold lol. Its not so hot u cant touch it by any means. Just warm. Just installed the new Bosch pump redid the lines and have a large front mount. So everything is good there. Maybe I was just expecting it to be alot colder. But its not hot just not super cold. So the heat tape can't hurt.
Right, the tape can't hurt... I just didn't really like the look of it. It may help to bring the water temps down a few degrees.
Yes, this is the most efficient way to route the plumbing. Gives a good counter-flow setup and keeps the coldest water closest to the throttle body.
LOL, why did I hear that read back in a super gay voice
That's about what mine looked like with the standard pump, a gentle flow. Some people were discussing the fact that the Bosch pump might move fluid too fast and not allow it enough time in the heat exchanger to cool off... but I think the fluid spends more time in the large HX than it does in the AC because of their difference in size... The large HX is definitely larger in capacity than the AC. So I don't see how moving the liquid faster would hurt, as long as more time is spent in the HX than the AC.
Old 06-29-2013, 07:25 AM
  #25
james0933's Avatar
Get us some pics of your wrapped Aftercooler if you can.
Old 06-29-2013, 07:42 AM
  #26
lude92_si's Avatar
I will. Just got it. Only got 2"x15' so hope its enough. Stuff isn't cheap lol just have to find time. I know I'm not going to be a fan of the gold color. Oh well.
Old 06-29-2013, 09:45 AM
  #27
james0933's Avatar
http://forums.hybridz.org/topic/6500...=1#entry609736
Old 07-02-2013, 06:08 AM
  #28
james0933's Avatar
Jet hot coated
Old 07-16-2013, 11:05 AM
  #29
lude92_si's Avatar
Got the aftercooler wrapped up. Took it on a 45min drive around town stop and go on a 80 degree day. Stopped at a gas station on the way home and i must say it was cooler than i thought it would be! So from my hand test it has seemed to help. Deff. felt cooler by touch than when it was not wrapped. I have no way to check my AIT so i cant say if its cooled down my air charge but by it being cooler to the touch im sure its helped with heat soak. I will try to get a pic up. Im going to buy more to do my air box and tube going into the SC.
Old 07-16-2013, 01:12 PM
  #30
lude92_si's Avatar
Quick Reply: wrapping aftercooler?
