Wiring up resistor box...?
Ok so just getting done installing my turbosetup.
Not I bought this used and it had a resistor pack already wiring in. During the un-install on teh other end the wires kinda got messed up....
Here's some pics.... There's one red one tha tgoes to ignition switched 12v..
All teh rest are black.... Does i tmatter where they get wired in???
Look at the bottom picture. There's 4 black wires that clearly go tot eh yellow/black injector wires off the harness....
But the last black wire with black electrical tape on it.... does that go to ground?
Originally Posted by Kirpich,Nov 26 2008, 07:57 PM
Try that. Worst case scenario, a fuse blows. But try to find some installation instructions, either from a guy who sold you this box, or online.
he doesn't know....
But really i can tell which wires go to teh harness pretty easily. Just the one black wire that is left... must go to ground.
A resistor pack goes inline with the power feeds to your injectors.
The red wire is most likely the switched 12V that will be running through the resistor pack and feeding the injectors. All the blacks should be the 12V outputs to each injector. It shouldn't matter which black wire goes to which injector. Injector grounds should remain untouched from factory.
Hope this helps.
Darryl
Hope this helps.
Darryl
Ok, now I'm a bit confused. Shouldn't there be 8 wires then for injectors? 4 leads in, 4 leads out? and then 1 power, and 1 ground on top?
Or do you Tee into the injecor pulse wire with each lead?
Here is a link that has some wiring info
http://www.honda-tech.com/showthread.php?t...w+resistor+wire
