Wideband ELD Resistor 07 AP2
I ended up using the egrl input per my tuner (vitviper) for better air fuel readings at the pcm. Can't remember why but something to do with the input voltage readings are better on the egrl vs the eld input. Don't quote me on that though
Almost none of the AP2 ecu's have it -- Hondata can add the EGRL circuitry for you, and boost control (PWM circuit) for you if you send them the ECU.
The ELD input sucks because of the resistor (resistors? or even other circuitry possibly) preventing voltage readings below 1v (basically it always reads at least 1v no matter what). So with most widebands that amounts to not seeing below 12 afr or so. I'm not sure what circuitry needs to be modified to resolve this, or if it's even possible to do so on this ECU (it was on the old PRB RSX ECU's).
