Who uses turbo blankets?
As a install tip. I highly recommend using blue locktite (at the very least) and nordlock washers (see in pic with turbo blanket above) on the bolts to mount the Ptuning motor mount bracket to the engine block. The above mentioned bolts backed out over time (I actually lost one of the bolts somewhere on the road). The nord lock washers can only be mounted on the 3 hex bolts. The button head bolt should not have the washer due it having as much clearance as possible to rotate the turbo on the manifold to line up with the exhaust.
