What way to go
What way to go
Hi
I have been lurking as a non member over the past months looking for information about different turbo setups and sc setups. I think I have a fair understanding of the most common kits out there, and how much they would cost approx. (Not counting possible problems)
In any case, FI the Honda seem to be 5k$+ for the sneek solutions and 7-8k for a decent inlinepro turbo setup. Correct me if I am wrong. Then drivetrain costs add to that if the power exceeds ~300rwhp?
What I am thinking is that this spring I will turbo or SC my Honda 2 litre ym2005 european version. Will it be better to put some effort into the whole thing and build a own turbo setup from parts recommended by experienced turbo users or is it just better to get a kit? I do have knowledge in welding and i have a friend willing to help that did some custom homemade turbo setups. For example on the Porsche 928.
I would like 300-350rwhp. Also aiming for an efficient setup. Not too big injectors. Stock would ofcourse be lovely, but I guess it is in the grayzone.
Is the DIY route worth it? or should I just get some kit like kraftwerks when it comes out or maybe some secondhand inlinepro parts or maybe a vortech? Greddy maybe is an option too?
Looking for opinions from s2000 modders/drivers that actually DID the diy route.
Others advice are welcome too ofcourse.
Regards Henrik
Regards Henrik
If you can make a custom kit I'd go that route. 300-350hp will be VERY easy with a turbo - you can make 350 on only 7 psi! Keep your stock compression, go with a short top mount tubular for power and ease, 3"dp, 2.5" charge pipes, wide intercooler core (mine is 4"), and a GT30 series turbo with .62ar hotside and 3" outlet. Your spool up will be insane, and you'll make great power. You will probably hit nearly 400 on 9-10 psi and stock compression.
This is the setup that I have - and I'm making 400 on 11psi WITH lowered 9:1 compression. Don't worry about drivetrain stuff with only this much power. Stay away from launches on soft tires and you'll have a nice working driveline for years to come
Oh, definitely think about getting wider rear tires. 265/275 is the optimal width you'd want to go for IMO.
Intresting, so you say that 300-350 rwhp is reliable on a stock compression. I don't wanna kill my car and would like more opinions on this one. Have seen 7psi is "safe" in other threads tho.
Also I am not that familiar with the terms you use for describing your ideas on setup.
Would be glad if you could comment!
What is a tubular?
.62ar
Guess it is the volume/size of the exhaust side of the turbo?
What exactly is wide? The coolingpart of the intercooler? If yours is 4 inch, doesn't that mean the thickness in the cars drive direction?
Any thoughts on the injectors?
Any advice or guidelines for the exhaust manifold?
What is a tubular?
.62ar
