what size injectors?
i am going to purchase the inlinepro turbo kit for the s2k with all of the options. the only thing that is holding me back from ordering the kit is i cannot find decisive information on what size injectors to choose. i have looked through the entire forced induction forum and couldn't come up with anything.
i am first going to use a mild boost setting (10psi) because of my stock differential. then later i am going to get the inline pro diff kit and up the boost to about 17-18. i would like to only have to buy one set of injectors. now my question is this. is there an injector size out there that will be good for 10psi then later on be enough for 17-18 psi without having to change out the injectors?
Originally Posted by geists2k,Feb 6 2007, 03:36 PM
On a resistor box yes, with an injector driver, no. Depends on the skills of your tuner too.
There are also Saturated 750's. They do not require a resistor box or injector driver.
Tim
Tim
