What kind of horsepower loss when going to 9:1 CR
I recently had a massive engine failure and now have sent the block to Laskey Racing to be resleaved and all those other goodies that he does. I plan on turbocharging the engine in the near future. Knowing this, Mike has told me if I plan on turbocharging I might as well do it right and go with the 9:1 CR pistons instead of using the 3mm hg. This is fine, but the problem is that I am/was using this car as a daily driver and would like to be able to "cruise" around in the S2000 for the next couple of months until I can afford the inline pro turbo kit. (Probably 3-4 months until i can afford it)
My question for you guys is how much power loss can I expect if I go with 9:1 CR pistons before it is turboed? Will the car be even driveable, or is it a turbo or no run kind of thing when moving to 9:1 CR Pistons?
Another choice I have seen is that people raise compression for a NA car. Does anyone reccomend maybe i do this instead, and will be reliable?
Please give me some advice here, and try to stay away from the "what happend/How did it break" burns and questions because it is a long story resulting in me having to get my current motor built, or getting honda to replace/repair the motor for $7-8k.
Thanks guys. How do you know there will 30-40hp loss? Are the mathmatics that complicated or are you just going from experience? Also, is the 30-40 at the flywheel or tires?
If the end result you want is MUCH greater performance then turbo it well WORTH THE WAIT. You MIGHT pick up 15-20whp going 12-13:1cr properly tuned. Or you could loose 20whp for now put the turbo on and gain back 200+whp. Just my .02
I had a money shift right before the turbo install was supposed to take place and while it was at the dealership being repaired I had them put my 3mm hg on. Idrove th car for over a month on the stock ecu settings with lower CR. The car will feel pretty close to stock until you hit vtec and thats when you will be missing that extra compression. I know this first hand. But for daily driving I would assume that you don't need the vtec cam anyway.
Before I did this I was told that it wouldn't run, that it wouldn't start, that it would go into limp mode, and all kinds of other bs from people with no experience. Well I have been there done that and it doesn't affect anything but the hp up top.
[QUOTE=ChefJ,Jun 30 2007, 10:00 AM] I had a money shift right before the turbo install was supposed to take place and while it was at the dealership being repaired I had them put my 3mm hg on.
Mine makes ~20hp less then I was stock from 2-~4k rpms, once 4k hits my turbo spools and by 4.5k rpms I'm making more power there then I was at redline stock
Its worth it!
Its worth it!
