What clutch are you running in your car?
#41
finally got my clutch in from CLUTCH MASTER . im going with a stage 4 , 6 puck, with a chromoly steel 11 lb. flywheel. doing the install this sat. i'll let you guys know how it turns out
#42
"fulken" - there is absolutely no noise anywhere at any rpm PERIOD.......its just a tad stiffer than stock pedal pressure....and the stainless line will give you alittle more feedback and feel of the engagement than stock rubber line does.....this is an important cheap little mod that alot of guys don't do when changing clutches
"SilvCF2k" - the 2600lb pressure plate will hold 383 ft lbs.......with an OEM disc.....it just may wear a little faster than the ACT disc.....but you get a much smoother softer engagement for the street which is very noticable.....i have had no issues so far and i am almost at 13 lbs boost on the charger (high 300 HP range)and drag my car frequently
TWINCAMVTEC
11-22-2006 10:23 AM
