Which way does the oil flow in a sandwich plate?
Old 03-20-2010, 09:05 AM
boostedf22c's Avatar
[QUOTE=Artisan7471,Mar 19 2010, 03:49 PM] Oil flows up from the oil pump into the outer ring on the oil mounting boss on the block.
Old 03-20-2010, 03:18 PM
AusS2000's Avatar
I stand corrected!
Old 03-20-2010, 06:37 PM
Spoolin's Avatar
I must have been wrong then too. It must flow the opposite way I was thinking. Top AN fitting is OUT and the bottom AN fitting is IN.
Old 03-22-2010, 10:25 AM
goldenfri's Avatar
Thanks everyone.
Old 06-07-2016, 06:37 PM
MorngWoodStewie's Avatar
I know it's an old thread but don't want to confuse others that will read this. It won't matter cause each side of this plate the AN fitting leads to what someone said "bladder" either direction will flow it's direction back to it's outer ring "bladder"
If u inspect one each AN fitting leads to outside ring "bladder" just opposite sides.
hawkman199
08-22-2017 08:47 AM
EvasiveMotorsports
15
05-17-2017 02:18 PM
johnckeen
03-09-2017 02:56 AM
Quick Reply: Which way does the oil flow in a sandwich plate?
