Waterpump SOS kit
Waterpump SOS kit
Hey guys almost done fitting the kit and I'm stuck on where to get power for the pump.. The usual spot which is shown is taken by my defi gauges. Now question is can I put it somewhere else or should I splice it from the gauges?
I hooked it up directly to the battery through an automotive relay; essentially the same method that the Vortech kit suggests.
I originally spliced it in with my gauges (and heated seats) through the supplied accessory port by the ECU, but it was too much of a draw and my PLX mulit-gauge (specifically the wideband) wasn't functioning 100% of the time until I did the above.
Check 29 of the install guide (PDF page 41) of the following:
http://www.vortechsuperchargers.com/downlo...020-010v4.0.pdf
