Water/Meth mix
#21
^^^This is what I think. Its to prevent from pooling in our intake when not in use, which is bad news. But if your fluid and pump location makes it impossible for gravity to work then no worries. It clearly states in the directions to make sure these are mounted lower then your intake.
#22
Originally Posted by mys2k3,May 21 2010, 01:17 PM
You can have it read through the aem serial gauge. Jeff set mine up yesterday after my tune with him.
#23
I never installed a check valve. But the kit I got a couple of years ago never came with one, so I didn't worry about it.
I haven't noticed any issue because of this.
#24
Originally Posted by siadam,May 22 2010, 12:26 PM
What did you use, did you have to buy the gauge and sensor, and then he just used the aem serial gauge instead of setting up the extra gauge?
#25
[QUOTE=mys2k3,May 22 2010, 03:21 PM] I didn't buy anything extra. I was already using the aem serial gauge and Jeff figured some way to make the gauge show when the meth system was flowing.
#27
Originally Posted by mys2k3,May 22 2010, 03:59 PM
the controller on the kit already has the 0-5v output (blue wire). I'm pretty sure that's what we used.
#28
No flow gauge needed. It's not going to show the exact cc's being flowed but, i forget the conversion we used, it will show when the system is flowing up to when it is at peak flow.
#30
thats why a flow gauge t'd into the actual supply line will be 100% accurate.
