Water/Meth mix
I decided my AEM supplied check valve was causing more harm then good. I think it help speed up the reaction time of the injection to not run it. The pump and tank are below the nozzle anyway so Its not needed.
Originally Posted by siadam,May 21 2010, 12:18 PM
I used my check valve??
I don't really have any issues w/that as far as I'm aware, although I should look into the flow sensor, just to see make sure it is flowing, however I don't really want to deal w/another guage, would be nice if I could integrate that into my serial 18-1 setup.
Originally Posted by siadam,May 21 2010, 12:34 PM
That would only be IF the tank were above the nozzle?
Originally Posted by s2000Junky,May 21 2010, 02:26 PM
To keep it from draining back into the intake.
id leave it on if i was you or get a better valve from devils own.
Originally Posted by camuman,May 21 2010, 02:14 PM
i thought the check valve kept pressure from going thru the line and into the pump, IE backwards. with no check valve. if you where to not use the meth spray, then the intake being pressurized will shove air thru that line, past where the check valve woulda stopped it and allow it to pressureize the holding tank and pump.
The Check valve is to prevent the fluid being sucked out of the lines and into the intake..............At least I am 90% sure. Good chance I am wrong Either way it was causing an issue so I yanked it
