Water/Meth mix
Old 05-19-2010, 12:25 PM
mys2k3's Avatar
Default Water/Meth mix
Does a meth mix of 75% or higher damage any engine components like valve guides or anything else? I've heard of pure meth burning up parts but wondered about 75%.
Old 05-19-2010, 12:31 PM
JoeyBalls's Avatar
You'll be fine Turbo Buick guys have been running straight METH for YEARS...........
also we are injecting METH into the intake, not running it 100% via the gas tank
Old 05-20-2010, 05:23 AM
S2KB00ST's Avatar
What size injector would u run for 500whp on the AEM kit? Small, med or the large one?
Old 05-20-2010, 10:23 AM
JoeyBalls's Avatar
Large one
Old 05-20-2010, 10:43 AM
camuman's Avatar
at the very least, the large one. aem meth kit i find is great kit, but the nozzle sizes leave a lot to be desired.
devils own has huge selection of nozzles, and you can use devils own nozzle wiht aem piping
i make 350whp and spray the largest aem nozzle 515cc i think which is around 8gph + a devils own 2gph
Old 05-20-2010, 09:20 PM
s2000Junky's Avatar
I use the large nozzle as well. Currently running 100% meth, my car likes it.
AEM nozzle sizes
small = 130cc
Med = 315
Large = 550
I really like the atomization and spray pattern of the med nozzle though. I think with a more powerful pump/pressure, the larger nozzles could be better. I wouldn't trust going with anything larger then the supplied 550cc injector with the aem pump. I don't think it would atomize well enough to be safe/effective.
Old 05-21-2010, 06:50 AM
siadam's Avatar
AEM nozzle sizes
small = 130cc
Med = 315
Large = 550
The new pump looks like it does a pretty good job of atomizing the mixture from the video's I've seen (could be propaganda though, lol).
Old 05-21-2010, 07:36 AM
s2000Junky's Avatar
It’s sufficient at 150psi. I think the other pumps from Sno and Devils are 180-200psi. Those kits are also near twice the cost. AEM has built in safety features on the basic kit that these don’t have also. Pros and cons like anything.
Old 05-21-2010, 08:52 AM
JoeyBalls's Avatar
also, be VERY cautious of the Plastic Check Valve they give you. When I got the flow gauge the pump would come on and it would not sense flow for a good 2 seconds or so. Also after I was out of Boost the green LED would stay lit for a second or two........... I removed the Check valve and literally no delay from pump activation, to flow sensor..........
just something to think about.
I also read in a few articles that sometimes check valves cracking pressures could be off and they dont even bother with them
I got retuned today for the Meth to come on at the onset of Boost, the flow gauge read 550, nice and steady all the way to redline. I gained some mid-range and at 19psi (for the street) I make 561, whereas it was 550 before
Old 05-21-2010, 09:18 AM
siadam's Avatar
I used my check valve??
I don't really have any issues w/that as far as I'm aware, although I should look into the flow sensor, just to see make sure it is flowing, however I don't really want to deal w/another guage, would be nice if I could integrate that into my serial 18-1 setup.
Quick Reply: Water/Meth mix
