Wastegate question
Wastegate question
I'm upgrading to an electronic boost controller. This connects to the top of the wastegate correct? Also do you still run the bottom line from the wastegate to the turbo or does that eliminate it? Thanks
Out of the boost controller goes to the top of port in the wastegate.
The compressor housing, bottom port and inlet to the boost controller will all be T'ed off of each other.
s2kantstopme
02-23-2007 10:51 AM
XclusiveAutosports
09-21-2006 07:01 PM
