walbro fuel pump install
Old 11-02-2012, 06:03 PM
kerm1t's Avatar
Default walbro fuel pump install
Ive been looking up a whole bunch of diy's and the ones with pictures doesnt really mention anything about wiring. are the wires that came with the fuel pump necessary?
Old 11-02-2012, 06:20 PM
Former Sponsor
Moddiction's Avatar
You just remove the stock fuel pump and connect in the walbro into the housing. No wiring at all that I can remember. Reuse the Oem fuel sock as well. The walbro one interferes with the gas level indicator I believe.
Old 11-02-2012, 08:24 PM
crb5885's Avatar
No wiring required, like moddiction said, just unplug one and plug in the new ... i didnt have any trouble with the walbro sock, just make sure that you fill up your tank asap because your fuel gauge needs to re calibrate after being un plugged ... i ran out of gas and gauge read half tank .. oops!
Old 11-02-2012, 08:27 PM
miguel329's Avatar
I didnt know that.. nice to know!
Old 11-03-2012, 02:19 AM
kerm1t's Avatar
awesome thanks !!
Old 11-03-2012, 04:33 AM
TheSnail's Avatar
Is this true? I didnt do that when I installed a Walbro yesterday nor the Aeromitive it replaced.
Old 11-03-2012, 05:37 AM
Former Sponsor
Moddiction's Avatar
I didn't do it either. I don't think it is needed. You just need to make sure when you install it the sock is not held up by anything so it can float correctly to get the right readings.
Old 11-03-2012, 06:08 AM
steven975's Avatar
Moddiction, mine will not go under 2 bars at all.
Otherwise, it's pretty normal on the fuel levels. I thought I had made an error in installation, but if the pump interferes a little with the float, I guess my case is normal.
I am not about to go pull it to try to fix as 2 bars means fill-up time anyway.
Old 11-03-2012, 06:51 AM
Former Sponsor
Moddiction's Avatar
Did you reuse the oem fuel sock? The Walbro one supposedly gets caught up and does not read right. I have not used the Walbro one but was advised not to due to this reason. I have never had an issue with the fuel gauge using the oem sock.
Old 11-03-2012, 07:06 AM
steven975's Avatar
I'm using the OEM one. It's quite possible I screwed something up in the install and something is interfering with the float, but it works well enough as going under 2 bars is just asking for a lean condition in boost. I really just don't want to pull it out
Quick Reply: walbro fuel pump install
