Walbro 255 lph inconsistencies?
Old 08-09-2005, 10:26 PM
synapse's Avatar
Default Walbro 255 lph inconsistencies?
Guys, does anyone here that runs the Walbro have an in-cabin fuel pressure gauge where they can constantly watch the Walbro's performance. I think I'm getting some inconsistent performance from the Walbro, I just want to confirm this.
Anyone experience inconsistent performance from the Walbro?
Old 08-10-2005, 04:11 AM
blues2k3's Avatar
no problem here. We have run both single walbro and twin walbro in tank in the s2000. No problems so far. The fuel pressure remains fine. I have them running of twin 30 amp relays with 10 guage wire.
Old 08-10-2005, 05:11 AM
Sideways's Avatar
My first Walbro HP was petering out at higher rpms and when I replaced it the results were much better. I have been told by my tuner of several others that just replaced it with another of the same and did much better.
Old 08-10-2005, 10:43 PM
folex187's Avatar
I'm wondering if my pump is a source of my problems as well. My pressure drops after I rev and causes the engine to almost stall. It is similar to what would happen when my MAP sensor would need a wack but it is far worse. You can watch the gauge dip down well under 20psi then pop back up.
Old 08-11-2005, 04:09 AM
Tinker219's Avatar
you should never see below 43psi(Im pretty sure this is the stock idle pressure), assuming youre still on stock injectors.
Old 08-11-2005, 08:16 AM
synapse's Avatar
I'm seeing a 10 psi differential on flow with the Walbro I have installed. It correlates with whine as well. I'm going to get an industrial flow sensor and measure this to confirm
Old 08-11-2005, 08:18 AM
Tinker219's Avatar
if the RPM coincides with the whine, it might make sense if voltage to the pump drops; but if its just fluctuating inconsistent with RPM, you have problems somewhere...
Old 08-11-2005, 09:32 PM
synapse's Avatar
Well I noticed something weird tonight, when the fans came on the fuel pressure dropped 10 psi and came right back up. Unfortunately, I didn't have battery voltage being monitored to confirm. I could probably get current draw from the pump as well.
I tend to think that this pump just isn't very consistent.
Old 08-11-2005, 09:51 PM
folex187's Avatar
That happens to me too.
Old 08-12-2005, 07:56 AM
synapse's Avatar
I trolled around the LS1 message boards and even the LS1 V8 guys are seeing the same issues as well.
Quick Reply: Walbro 255 lph inconsistencies?
