Vtec Oil Pressure Block off
Nothing too special but I figured some of you guys might need it. Most, if not all EMS will not look for the vtec oil pressure sensor, so this is clean way to remove it. Price is $15 shipped.
When you get an EMS, it does not use the oil pressure sensor off of the vtec solenoid like stated above. Depending on your turbo kit, you may need to remove the plug for the sensor. Rather than having an open plug sticking off the vtec solenoid, you can remove the whole sensor and thread this bolt in its place to make it look nicer. Its a cosmetic mod that cleans things up mostly.
With my InlinePro sidewinder manifold, I actually melted the end of my vtec sensor plug as its right next to the down pipe. I just bought one of these for my car while at Full Blown yesterday to replace that melted sensor.
Originally Posted by cyber gook' timestamp='1303686820' post='20502604
So if you loose this, what was the point of it in the first place?
