Vortech water pump part number
Does anyone know the part number for the aftercooler water pump that comes with the vortech kit? Mine died so need a new one. and if anyone can recommend wheres a good place to order one, that'd be appreciated as well
Thanks
Thanks
look up ford lightning water pump on Summit racing.
http://store.summitracing.com/partdetail.a...15&autoview=sku
Prefer the CRS water pumps Higher capacity/flow especially good if you are using a large front heat exchanger on your air to water like me.
My aftercooler burns! lol
I had Tony Fuchs check out the relay and whether its getting power and it does get power there. So we concluded the pump is out =\
Originally Posted by 9kFever,Aug 13 2008, 04:57 PM
I had trouble with first my fuse burning out and then the ground wire that comes off the pump came loose.
That would be great news, since I don't look forward to replacing the pump itself with my limited skills and time!
I just found this, and I couldn't help but wonder what the ideal pressure for a water-to-air intercooler is.
"This information is directly from Bosch. Unit conversion shows that this pump flows 317 GPH; any seller who advertises differently is incorrect."
Found near the bottom of this page:
http://www.frozenboost.com/product_info.ph...608a891621d2b14
So far, this is the cheapest BOSCH water pump I've found online @ $120.00.
MinS2K
08-03-2008 12:04 PM
