Is This a VORTECH or COMPTECH kit?
Old 10-30-2012, 01:02 PM
  #21
volcomboy390's Avatar
Originally Posted by Kyushin
Originally Posted by volcomboy390' timestamp='1351584896' post='22117429
[quote name='eseDOSke' timestamp='1351584584' post='22117425']
It's a newer version ct-engineering/comptech kit with the novi 1220SL blower.
awwwww i see! I thought i was going crazy or something. Any pros and cons on the new 1220 blower.... or just pros
If its oil fed then youre fine, but if its the SL version you need to change to oil fed asap as they have been insanely prone to failure. The change is a quick turn around from paxton and pretty cheap I believe... hell even do a novi 1200 while youre at it
[/quote]
confirmed... it is a 1220sl how much do you think for the change to non-sl.
Old 10-30-2012, 08:40 PM
  #22
eseDOSke's Avatar
Don't be scared of the 1220SL. Just monitor the SC oil. Check it every so often and keep it topped off. Although a lot of people have had failures, there are more 1220SL owners that haven't had any issues with them. You'll know it's going bad if it starts making bad noises.
If you upgrade to the 1200, you'll need larger injectors if you don't have them already, a 4 bar map sensor, and a flash pro ready for another tune session. An upgraded clutch and flywheel will be needed also.
Good luck with your purchase.
Old 10-30-2012, 08:55 PM
  #23
If you upgrade to the 1200, you'll need larger injectors and a flash pro ready for another tune session if you don't have it already. An upgraded clutch and flywheel will be needed also.
He says the clutch is a brand new act clutch, idk what stage. Does anyone know how much additionally you would pay Paxton trading a 1220sl for a 1200.
Any threads for converting the 1220sl to oil fed?
Old 10-31-2012, 11:06 AM
  #24
jdmdohcpower's Avatar
Dont convert!
I asked Jeff Evans about this when I got tuned. He said the SL's are the one he finds the most problematic. He recomended engine feed oil even if you just buy a new kit today.
Old 10-31-2012, 12:50 PM
  #25
Former Sponsor
Moddiction's Avatar
^Thats exactly why he wants to conver it to engine oil fed lol.
Old 10-31-2012, 05:05 PM
  #26
Originally Posted by jdmdohcpower
Dont convert!
The supercharger IS a SL.... so your saying i SHOULD convert???
Is there a kit i can buy or can i piece together a kit to convert the 1220SL into a oil fed 1220?????? Or is my only option upgrading to a novi 1200... iv had people tell me I can... and I can't, so anyone with experience or knowledge on this would help me out alot. thx
Old 10-31-2012, 06:53 PM
  #27
Reapur's Avatar
Originally Posted by jdmdohcpower' timestamp='1351710401' post='22121131
Dont convert!
Sell everything and go Turbo. You wont regret it :-D
Old 10-31-2012, 08:48 PM
  #28
Originally Posted by Reapur
Originally Posted by volcomboy390' timestamp='1351731952' post='22121894
[quote name='jdmdohcpower' timestamp='1351710401' post='22121131']
Dont convert!
[/quote]
lol I live in Cali and its my dd so id rather not risk it. Gota go to work and all so its this or greddy
Old 11-01-2012, 01:08 PM
  #29
SgtDuracell's Avatar
i hear the 1220 blowers can't pulley down as much as the 1200s because of the mounting bolts hitting the pulley when u downsize it...
Old 11-01-2012, 01:53 PM
  #30
eseDOSke's Avatar
Yup, just installed a larger crank pulley extension that was custom made by CT-Engineering. Now I'm boosting around 9.5-10lbs. I have to get a smaller blower pulley made by CT to boost 12psi. You'll have to do a slightly smaller than original size blower pulley and a larger crank pulley extension if you want to go beyond 10psi on the newer CT 1220 kits.
It's actually pretty good to help eliminate belt slippage.
Quick Reply: Is This a VORTECH or COMPTECH kit?
