Vortech Comptech
Vortech Comptech
When I received my comptech kit it wasn't complete. I called comptech and they haven't gotten back to me yet for replacement parts. Does any one know where I could possibly find some? I was also wondering if a vortech modified stock crank pulley would work with the ctsc pulley. what im missing from the ctsc kit is modified stock crank pulley, 6x70mm and 10x45mm bolts that hold the sc, the fuel rail o ring adaptor for the fpr, banjo bolt and crush washers for the fpr, alternator extension, the -an fittin for the oil on the compressor side of the sc is damaged, and this black plastic piece for the intake tube its kinda hard to explain, and I don't know exactly what its called.
Thanks! Do you know of any thing i can use "instead" I know the crank pulley and alternator extension are comptech specific. But can I use a different fpr instead of the comptech supplied one? I'm sure I can find the 6x70mm and 10x45mm bolts somewhere.
See if you can make a friend with a Comptech kit and talk to a machine shop about duplicating both pieces you need. They are very application specific. Or get in contact with the seller of your used kit and see if you can persuade them into supplying the missing parts.
i called comptech and i guess the secretary told me "nate" was on the phone and he is the person i should talk to about replacement parts but he was on the phone and i left him a message. they're out of business but they still answer the phones? oh well ill just have to see if i can come up with some kind of alternatives. thanks guys.
