Vibration
Took the car out for the first time .Huge vibration coming from the back of the car whilst on low revs like 2k or so. I have a v160 and a steel drive shaft from DSS and 8.8 diff. Have somebody had same issues with the same set up ?.
I will start from removing the dump tube it is touching the engine and making a rattling noise. I will try the drive shaft after, we never aligned it after we installed it.
The vibration is coming from the bell housing very strange. When i drive the car and put it on neutral gear the vibration goes away. Any suggestions? Would help a lot.
Beyond that though I'm wondering if there's any possibility there could be an issue with the pressure plate/flywheel torque. Just anything that could cause rattling by the bellhousing. Check that the clutch fork is properly pulling the TOB?
I'd just start checking all your bases until you hit something.
jor-don
06-16-2014 07:43 AM
golfnut311
03-18-2013 05:20 PM
EssToOfouzEn
06-28-2012 10:24 PM
